Aller au contenu principal
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 2 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 1
Étape 1
Use a thin pry tool or tweezers to carefully pry up and disconnect the upper coaxial cable connector from the logic board. There are two coaxial connectors in close proximity. Disconnect the one nearest the battery connector.
  • Use a thin pry tool or tweezers to carefully pry up and disconnect the upper coaxial cable connector from the logic board.
  • There are two coaxial connectors in close proximity. Disconnect the one nearest the battery connector.
  • During reassembly, this can be tricky to reconnect. Hold the connector in place over its socket and press down with the flat of your spudger. The connector should snap into place.
Insérez ici votre traduction
