Aller au contenu principal
Info : Vous modifiez un tutoriel pré-requis. Toutes les modifications apportées affecteront les tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 4
Étape 4
Approach this step with the process of unbuttoning a shirt in mind. Be careful if the rubber gasket is dry-rotted.  Use vaseline to re-moisturize if necessary.  Manipulating dry-rotted rubber will result in tearing.
  • Approach this step with the process of unbuttoning a shirt in mind.
  • Be careful if the rubber gasket is dry-rotted. Use vaseline to re-moisturize if necessary. Manipulating dry-rotted rubber will result in tearing.
  • Pinch the bottom of the rubber gasket at the left side of the assembly and remove it from the plastic "buttons" on the headlight assembly.
Insérez ici votre traduction
