Aller au contenu principal
Info : Vous modifiez un tutoriel pré-requis. Toutes les modifications apportées affecteront les tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 5
Étape 5
Locate the blue headlight wire. Use a flathead screwdriver to pry up one side of the clamping teeth and pull the connector off. Locate the green turn signal wire clamp. Use a flathead screwdriver to push in the tab on the side and pull off the connector.
  • Locate the blue headlight wire. Use a flathead screwdriver to pry up one side of the clamping teeth and pull the connector off.
  • Locate the green turn signal wire clamp. Use a flathead screwdriver to push in the tab on the side and pull off the connector.
  • Now that all connections between the car and the headlight assembly are disconnected, it is safe to remove the headlight assembly from the truck.
Insérez ici votre traduction
