Aller au contenu principal
Info : Vous modifiez un tutoriel pré-requis. Toutes les modifications apportées affecteront les tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 3
Étape 3
Use the 10 mm socket wrench to unscrew the first of three 12 mm long 10 mm hex-head screws holding in the headlight assembly. The screw is located just to the left of the headlight assembly. Unscrew the second screw located approximately 6 inches below the first. Locate the third screw at the bottom left corner of the headlight assembly just behind the bumper and remove.
  • Use the 10 mm socket wrench to unscrew the first of three 12 mm long 10 mm hex-head screws holding in the headlight assembly. The screw is located just to the left of the headlight assembly.
  • Unscrew the second screw located approximately 6 inches below the first.
  • Locate the third screw at the bottom left corner of the headlight assembly just behind the bumper and remove.
  • When re-installing the screws do not over tighten. Over tightening the screws will result in stripped threads.
Insérez ici votre traduction
