Aller au contenu principal
Anglais
Français
Traduction de l’étape 3
Étape 3
Carefully lift the display screen and you'll find the screen held by three delicate ribbon cables.  You can fold the screen up to work on these three cables. The ribbon cable is held down to the connectors with a custom-shaped piece of tape.  Carefully peel the tape up and off of the connectors and ribbon cable.  Set it aside on some waxed paper. I sandwiched the ribbon cable tape in waxed paper and kept a weight down on it until I was ready to re-use it.  If I had thought of it I would have paid the $3 for the ifixit replacement tape.
Lift Screen
  • Carefully lift the display screen and you'll find the screen held by three delicate ribbon cables. You can fold the screen up to work on these three cables.
  • The ribbon cable is held down to the connectors with a custom-shaped piece of tape. Carefully peel the tape up and off of the connectors and ribbon cable. Set it aside on some waxed paper.
  • I sandwiched the ribbon cable tape in waxed paper and kept a weight down on it until I was ready to re-use it. If I had thought of it I would have paid the $3 for the ifixit replacement tape.
  • Each cable is held in a ZIF connector. A small clip lifts up and forward. Use a spudger between the clip and the module behind it and carefully pop the clip up.
  • With the ZIF clips opened up, carefully pull each ribbon cable from its connector and set the display screen aside.
Insérez ici votre traduction
