Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Anglais
Français
Traduction de l’étape 5
Étape 5
A Tri-Wing Y000 screw (.6 mm) holds an adhesive label on top of the Taptic Engine.  The label also hides the connector for the Force Touch Gasket.  Remove the screw and peel up the label.  It takes a little effort to peel the cover/label due to some adhesive. A gold colored connector sits on top of the force touch sensor module.  Pop up the connector and lift up the force touch sensor module. Using tweezers, pull up the force touch sensor gasket starting at one side and going around the watch until the gasket lifts out.
Get To The Engine
  • A Tri-Wing Y000 screw (.6 mm) holds an adhesive label on top of the Taptic Engine. The label also hides the connector for the Force Touch Gasket. Remove the screw and peel up the label. It takes a little effort to peel the cover/label due to some adhesive.
  • A gold colored connector sits on top of the force touch sensor module. Pop up the connector and lift up the force touch sensor module.
  • Using tweezers, pull up the force touch sensor gasket starting at one side and going around the watch until the gasket lifts out.
Insérez ici votre traduction
