Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Anglais
Français
Traduction de l’étape 1
Étape 1
Remove 6 screws in the handle. Using a jimmy, thin spatual or other prying tool, separate the two halves of the handle.
Handle
  • Remove 6 screws in the handle.
  • Using a jimmy, thin spatual or other prying tool, separate the two halves of the handle.
  • As you separate the two halves, try not to let the trigger spring take flight. On reassembly, make sure the two pegs on the trigger are fitted into their slots and the spring is in place.
  • As you separate the halves of the handle, the lamp assembly may stay with the upper half you are removing. Transfer it to the lower half for reassembly. Ensure all parts are fitted snugly in their proper positions and that wires are tucked away so as not to be pinched when the handle is closed.
  • If you need to, you can now lift out the circuit board for inspection, or lift out the battery for testing or replacement.
Insérez ici votre traduction
