Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront le tutoriel qui comprend ces étapes.
Anglais
Français
Traduction de l’étape 7
Étape 7
If you successfully removed the entire ambient light sensor, as shown in the first photo, continue to the next step below. If the white diffuser strip detached and remains embedded in the display, as shown in the second photo, you will need to carefully lever it out along the top edge using a thin blade or pry tool. Re-applying heat first may make this task a bit easier. During reassembly, install the diffuser into the display first, making sure it faces the right direction (the front-facing side is shown in the first image, and the rear-facing side is shown in the third).
  • If you successfully removed the entire ambient light sensor, as shown in the first photo, continue to the next step below.
  • If the white diffuser strip detached and remains embedded in the display, as shown in the second photo, you will need to carefully lever it out along the top edge using a thin blade or pry tool. Re-applying heat first may make this task a bit easier.
  • During reassembly, install the diffuser into the display first, making sure it faces the right direction (the front-facing side is shown in the first image, and the rear-facing side is shown in the third).
  • Then, set the ambient light sensor on top of the diffuser. You will need to hold the sensor in position while installing the screws securing the earpiece/sensor assembly. Once the screws are tightened, the sensor will stay in place and work normally.
Si vous avez réussi à retirer tout le capteur de luminosité ambiante comme illustré sur la première photo, allez directement à l'étape suivante.
Si la bande blanche du diffuseur s'est détachée et est restée coincée dans l'écran, comme illustré sur la deuxième photo, vous allez devoir faire levier avec une fine lame ou un outil de levier tout le long du bord supérieur pour l'enlever. Refaites chauffer d'abord le tout, la tâche sera peut-être un peu plus facile ensuite.
Lors du remontage, posez d'abord le diffuseur dans l'écran, en veillant à ce qu'il soit orienté correctement (on voit la face avant sur la première image et la face arrière sur la troisième).
Puis, posez le capteur de luminosité ambiante en haut du diffuseur. Vous devrez maintenir le capteur en place pendant que vous vissez les vis fixant l'ensemble haut-parleur interne/capteurs, Une fois que vous aurez serré les vis, le capteur restera en place et fonctionnera normalement.
