Aller au contenu principal
Anglais
Français
Traduction de l’étape 12
Étape 12
We carefully extract the left eyeball wide angle camera, which is lightly adhered to the frame. According to Google, this extra camera will let you fit more of your friends into your selfies, which makes them ... Group-ies? On the back, Google is again betting that AI can help a single sensor to do the work of two.
  • We carefully extract the left eyeball wide angle camera, which is lightly adhered to the frame.
  • According to Google, this extra camera will let you fit more of your friends into your selfies, which makes them ... Group-ies?
  • On the back, Google is again betting that AI can help a single sensor to do the work of two.
  • Based on early reviews, they may be right. Word on the street is, this is a slightly upgraded Sony IMX363 sensor—the rest is up to the Pixel Visual Core.
  • A Knowles MEMS microphone is also seen in the top center of the case
Nous extrayons soigneusement la pupille gauche caméra grand angle qui adhère légèrement au châssis.
D'après Google, cette caméra permettra d'inclure plus d'amis dans vos selfies qui seront donc des … groupies ?
Au dos, Google parie encore une fois que l'intelligence artificielle peut aider un seul capteur à faire le travail de deux.
Les premiers tests semblent le confirmer. La rumeur dit qu'il s'agit d'un capteur Sony IMX363 légèrement amélioré – Pixel Visual Core se charge du reste.
[* black] We carefully extract the ~~left eyeball~~ wide angle camera, which is lightly adhered to the frame.
[* icon_note] According to Google, this extra camera will let you fit more of your friends into your selfies, which makes them ... Group-ies?
[* black] On the back, Google is again betting that AI can help a single sensor to do [https://www.redmondpie.com/iphone-xs-optical-zoom-vs-pixel-3-super-res-zoom-comparison/|the work of two|new_window=true].
[* black] Based on early reviews, they may be right. Word on the street is, this is a [https://www.xda-developers.com/google-pixel-3-sony-imx355-imx363-camera-sensor/|slightly upgraded Sony IMX363|new_window=true] sensor—the rest is up to the Pixel Visual Core.
[* black] A Knowles MEMS microphone is also seen in the top center of the case
