Aller au contenu principal
Anglais
Français
Traduction de l’étape 2
Étape 2
Grab your new piece of thermal pad and cut it to the sizes you need using a pair of scissors. Some residue might cover a larger area than the marking which is due to the fact that the thermal pad will be squished down flat. In this case stick to the size of the marking for the new pad not the size of the residue. Some residue might cover a larger area than the marking which is due to the fact that the thermal pad will be squished down flat. In this case stick to the size of the marking for the new pad not the size of the residue.
cutting the new pads
  • Grab your new piece of thermal pad and cut it to the sizes you need using a pair of scissors.
  • Some residue might cover a larger area than the marking which is due to the fact that the thermal pad will be squished down flat. In this case stick to the size of the marking for the new pad not the size of the residue.
Prenez votre bande neuve de pâte thermique et coupez-la aux dimensions nécessaires avec une paire de ciseaux.
Il se peut que les résidus dépassent de la marque, car le pad thermique est écrasé et aplati lors du montage. Dans ce cas, respectez la taille de la marque et non du résidu.
