Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 6 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 1
Étape 1
Use the point of a spudger to lift and disconnect the antenna cable from the bottom end of the logic board. To reconnect antenna cables like these to the socket, carefully align the connector to the socket, then use the flat end of a spudger to press down. It should click in place. If not, check for alignment. Do not use excessive force.
  • Use the point of a spudger to lift and disconnect the antenna cable from the bottom end of the logic board.
  • To reconnect antenna cables like these to the socket, carefully align the connector to the socket, then use the flat end of a spudger to press down. It should click in place. If not, check for alignment. Do not use excessive force.
Utilisez la pointe d'une spatule (spudger) pour soulever et déconnecter le câble d'antenne de l'extrémité inférieure de la carte mère.
