Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 3 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 2
Étape 2
Remove the 11mm screw from the right side of the  Hard Drive access panel using a Phillips #0 screwdriver. Remove the 3.5 mm screw from the left side of the access panel using a Phillips #0 screwdriver.
  • Remove the 11mm screw from the right side of the Hard Drive access panel using a Phillips #0 screwdriver.
  • Remove the 3.5 mm screw from the left side of the access panel using a Phillips #0 screwdriver.
  • Use a plastic opening tool to pry off the access panel from the bottom.
Insérez ici votre traduction
