Aller au contenu principal
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 3 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 5
Étape 5
Remove the sixteen 8 mm Phillips #2 screws with flanges from the horizontal side of the plate by turning the screwdriver counterclockwise. Remove the ten 8 mm Phillips #2 screws with flanges from  the vertical sides of the plate by turning the screwdriver counterclockwise. Remove the ten 8 mm Phillips #2 screws with flanges from  the vertical sides of the plate by turning the screwdriver counterclockwise.
  • Remove the sixteen 8 mm Phillips #2 screws with flanges from the horizontal side of the plate by turning the screwdriver counterclockwise.
  • Remove the ten 8 mm Phillips #2 screws with flanges from the vertical sides of the plate by turning the screwdriver counterclockwise.
Insérez ici votre traduction
