Aller au contenu principal
Anglais
Français
Traduction de l’étape 6
Étape 6
Loosen and remove the two bolts located on the backside of the caliper with a 12mm socket. Torque the two bolts to 33 ft-lbs when putting the caliper back on the mounting bracket. Remove the caliper from the mounting bracket.
  • Loosen and remove the two bolts located on the backside of the caliper with a 12mm socket.
  • Torque the two bolts to 33 ft-lbs when putting the caliper back on the mounting bracket.
  • Remove the caliper from the mounting bracket.
  • Do not allow the caliper to hang freely. This will causes stretching or internal blocking of the brake line.
  • TIP: Using hang wire to hang the caliper on the spring mount to keep it out of the way.
Insérez ici votre traduction
