Aller au contenu principal
Anglais
Français
Traduction de l’étape 7
Étape 7
Use a pry bar to remove the old brake pad from the bracket. Use the same procedure for removing the pads on the other sides.
  • Use a pry bar to remove the old brake pad from the bracket.
  • Use the same procedure for removing the pads on the other sides.
  • TIP: Using C-clamp to compress the caliper to refit the new brake pads
  • After removing the pads, you can check the rotor for irregular wear or damage. Run your finger across the face of the rotor to feel for grooves or chipping.
Insérez ici votre traduction
