Aller au contenu principal
Anglais
Français
Traduction de l’étape 8
Étape 8
Pull the two caliper pins out of the mounting bracket by hand. If needed,  apply "Brake Lubricant" to the two caliper pins. This fights corrosion buildup and allows the pins to slide off more smoothly. Before putting the new brake pads on, apply "Disc Brake Quiet" compound to the metal backing of the pads to keep them from squeaking.
  • Pull the two caliper pins out of the mounting bracket by hand.
  • If needed, apply "Brake Lubricant" to the two caliper pins. This fights corrosion buildup and allows the pins to slide off more smoothly.
  • Before putting the new brake pads on, apply "Disc Brake Quiet" compound to the metal backing of the pads to keep them from squeaking.
Insérez ici votre traduction
