Aller au contenu principal
Info : Vous modifiez actuellement un pré-requis du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 2 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 4
Étape 4
Remove the four 13mm screws that hold the black plastic cover using the Phillips #2 screwdriver. Gently remove the black cover. Underneath you will see a clear plastic cover that should be removed as well. Gently remove the black cover. Underneath you will see a clear plastic cover that should be removed as well.
  • Remove the four 13mm screws that hold the black plastic cover using the Phillips #2 screwdriver.
  • Gently remove the black cover. Underneath you will see a clear plastic cover that should be removed as well.
Insérez ici votre traduction
