Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Anglais
Français
Traduction de l’étape 3
Étape 3
There are 3 screws holding the outer metal cover on. This reveals the circuit board. Be careful not to lose the rubber around the mic. Make sure you don't lose the power switch.
  • There are 3 screws holding the outer metal cover on.
  • This reveals the circuit board. Be careful not to lose the rubber around the mic.
  • Make sure you don't lose the power switch.
  • Ribbon cable safety: Don't shear side to side. Don't twist. If disconnecting disconnect it using a pry tool at the connector, never by pulling up on the cable!
  • THIS IS OPTIONAL. Only do this if you need to: If removing the ribbon cable, once this cable is disconnected you can gently pull up on it (not bending too sharply!) to detach the adhesive from the speaker chamber
  • 3rd picture shows prying upwards on the edge of the ribbon connector. It has some glue that must be pushed aside. It is weak so you can probably just pry up on the ribbon connector.
Insérez ici votre traduction
