Aller au contenu principal
Info : Vous modifiez un tutoriel pré-requis. Toutes les modifications apportées affecteront les tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 8
Étape 8
Locate the two clips on the inside of the case and use the spudger tool to detach them from the case.  To detach each clip, use the sharp end to press the small, black plastic in the center of the clip. Locate the two clips on the inside of the case and use the spudger tool to detach them from the case.  To detach each clip, use the sharp end to press the small, black plastic in the center of the clip. Locate the two clips on the inside of the case and use the spudger tool to detach them from the case.  To detach each clip, use the sharp end to press the small, black plastic in the center of the clip.
  • Locate the two clips on the inside of the case and use the spudger tool to detach them from the case. To detach each clip, use the sharp end to press the small, black plastic in the center of the clip.
Insérez ici votre traduction
