Aller au contenu principal
Info : Vous modifiez actuellement un pré-requis du tutoriel que vous venez de consulter. Toutes les modifications affecteront le tutoriel% qui comprend cette étape.
Traduction de l’étape 2
Étape 2
Carefully lift the connector for the LED indicator light straight up to disconnect it from its socket on the logic board. Take care not to pry under the socket, or you may break it off the board.
  • Carefully lift the connector for the LED indicator light straight up to disconnect it from its socket on the logic board.
  • Take care not to pry under the socket, or you may break it off the board.
Soulevez le connecteur du voyant LED tout droit vers le haut pour le déconnecter de sa prise sur la carte mère.
[* black] Carefully lift the connector for the LED indicator light straight up to disconnect it from its socket on the logic board.
[* icon_caution] Take care not to pry under the socket, or you may break it off the board.
