Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 8 tutoriels qui comprennent cette étape.
Traduction de l’étape 6
Étape 6
Unscrew the logic board connector cover
Remove the five screws securing the logic board connector bracket to the rear case:
One 1.3 mm Phillips #000 screw
One 1.5 mm Phillips #000 screw
Three 1.2 mm Y000 screws
Remove the bracket.
[title] Unscrew the logic board connector cover |
[* black] Remove the five screws securing the logic board connector bracket to the rear case: |
[* red] One 1.3 mm Phillips #000 screw [* orange] One 1.5 mm Phillips #000 screw |
[* yellow] Three 1.2 mm Y000 screws |
[* black] Remove the bracket. |
[* icon_note] Be careful not to lose the [https://d3nevzfk7ii3be.cloudfront.net/igi/BLoNCtTggDqOfLxl|smaller bracket|new_window=true] clipped onto the edge. It's secured with a [https://d3nevzfk7ii3be.cloudfront.net/igi/XcoV2gOk5ISoxJLN|small clip|new_window=true] and is easy to accidentally knock off of the larger bracket. |
