Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 2 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 9
Étape 9
Remove the earpiece speaker and front sensor assembly. During reassembly, check the position of the black plastic module containing these components: Proximity sensor
Remove the speaker + front sensors
  • Remove the earpiece speaker and front sensor assembly.
  • During reassembly, check the position of the black plastic module containing these components:
  • Proximity sensor
  • Flood illuminator
  • The module must be positioned so that these components are not obstructed by any adhesive.
Retirez l'ensemble haut-parleur interne et capteurs avant.
Lors du remontage, vérifiez la position du module en plastique noir qui comprend ces composants :
Capteur de proximité
Illuminateur infrarouge
Il faut positionner ce module de sorte que ces composants ne soient pas encombrés d'adhésif.
[title] Remove the speaker + front sensors
[* black] Remove the earpiece speaker and front sensor assembly.
[* icon_reminder] During reassembly, check the position of the black plastic module containing these components:
[* red] Proximity sensor
[* orange] Flood illuminator
[* yellow] The module must be positioned so that these components are not obstructed by any adhesive.
