Aller au contenu principal
Info : Vous modifiez un tutoriel pré-requis. Toutes les modifications apportées affecteront les tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 1
Étape 1
Remove the remaining 7 mm screws on the back panel of the laptop with a Phillips #0 screwdriver. Use the plastic opening tool to pry up a corner of the back panel and continue to pop the back panel off. Expect to hear popping as you pull the back panel off.
  • Remove the remaining 7 mm screws on the back panel of the laptop with a Phillips #0 screwdriver.
  • Use the plastic opening tool to pry up a corner of the back panel and continue to pop the back panel off.
  • Expect to hear popping as you pull the back panel off.
Insérez ici votre traduction
