Aller au contenu principal
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 6 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 1
Étape 1
Using a T5 screwdriver bit, remove the (6) 5.0 mm screws along the outside edge of the frame. Using a metal spudger, wedge the 6 plastic tabs molded into the outer shell away from the frame to lift up and remove it. Using a metal spudger, wedge the 6 plastic tabs molded into the outer shell away from the frame to lift up and remove it.
  • Using a T5 screwdriver bit, remove the (6) 5.0 mm screws along the outside edge of the frame.
  • Using a metal spudger, wedge the 6 plastic tabs molded into the outer shell away from the frame to lift up and remove it.
Insérez ici votre traduction
