Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Anglais
Français
Traduction de l’étape 5
Étape 5
With the heatsink assembly removed, the motherboard is accessible, and after removing a couple brackets we can pull the assembly from the case. The motherboard contains many soldered-on ports, which can be high wear components. If you need to replace them, it will require an expensive motherboard replacement.
  • With the heatsink assembly removed, the motherboard is accessible, and after removing a couple brackets we can pull the assembly from the case.
  • The motherboard contains many soldered-on ports, which can be high wear components. If you need to replace them, it will require an expensive motherboard replacement.
  • The CPU and GPU are also soldered onto the board, eliminating the chance for upgrade—an increasingly rare option for laptops these days.
  • The fingerprint sensor is removable after the battery and its bracket are dispatched.
  • The SD card slot and headphone jack port board is removable after the speakers. These are great components to make modular as they receive wear and will be a cheap replacement component.
  • The final removable component is the CMOS battery on the back of the motherboard.
Insérez ici votre traduction
