Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Anglais
Français
Traduction de l’étape 3
Étape 3
To protect the internal cables and components, you will need to carefully disconnect  the battery connector. Ensure the 1.3 mm Phillips #000 screws securing the metal plate is removed with a Phillips 000 screwdriver. Remove the metal plate with tweezers.
  • To protect the internal cables and components, you will need to carefully disconnect the battery connector. Ensure the 1.3 mm Phillips #000 screws securing the metal plate is removed with a Phillips 000 screwdriver.
  • Remove the metal plate with tweezers.
  • Disconnect the battery connector from the motherboard using the spudger.
Insérez ici votre traduction
