Aller au contenu principal
Info : Vous modifiez actuellement un pré-requis du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 9 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 1
Étape 1
Pull the hard drive away from the front edge of the mini and remove it from the outer case. During reassembly, there are two pins on the inside edge of the hard drive that fit into the case. The holes have rubber grommets around them, so it may be difficult to tell when you have seated the hard drive correctly.
  • Pull the hard drive away from the front edge of the mini and remove it from the outer case.
  • During reassembly, there are two pins on the inside edge of the hard drive that fit into the case. The holes have rubber grommets around them, so it may be difficult to tell when you have seated the hard drive correctly.
  • There are two pairs of holes in the case. Insert the pins into the holes closest to the bottom of the case.
Dégagez le disque dur du bord avant du mini et retirez-le du boîtier extérieur.
Lors de la réinstallation, vous trouverez deux broches sur la face interne du disque dur qui se fixent sur le boîtier extérieur. Comme les emplacements des broches sont couverts d'une protection en gomme, vous aurez peut-être des difficultés à voir si le disque dur est bien installé.
[* black] Pull the hard drive away from the front edge of the mini and remove it from the outer case.
[* icon_note] During reassembly, there are two pins on the inside edge of the hard drive that fit into the case. The holes have rubber grommets around them, so it may be difficult to tell when you have seated the hard drive correctly.
[* icon_note] There are two pairs of holes in the case. Insert the pins into the holes closest to the bottom of the case.
