Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Info : Vous modifiez actuellement un prérequis du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 7 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 2
Étape 2
Pull the silver metal AC-In socket retainer away from the side of the outer case and remove it from the mini. During reassembly, notice that the silver clip hugs either side of the lower beveled edge of the AC connector. When sliding the clip back in it will hit a stop, but not click into place. You will know that you did it correctly because it will not easily move out of position. During reassembly, notice that the silver clip hugs either side of the lower beveled edge of the AC connector. When sliding the clip back in it will hit a stop, but not click into place. You will know that you did it correctly because it will not easily move out of position.
  • Pull the silver metal AC-In socket retainer away from the side of the outer case and remove it from the mini.
  • During reassembly, notice that the silver clip hugs either side of the lower beveled edge of the AC connector. When sliding the clip back in it will hit a stop, but not click into place. You will know that you did it correctly because it will not easily move out of position.
Tirez la patte de fixation en métal argenté qui maintient le support de la prise d'entrée CA (AC-In) sur le côté du boîtier extérieur et sortez-la du mini.
