Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 3 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 1
Étape 1
Before removing the battery from the device be sure not to puncture the battery. Since the battery is a form of acid. Using a plastic pry tool is better than a metal tool when working with wire and soft case battery case. Use a plastic pry tool to remove the battery connector from the logic board.
  • Before removing the battery from the device be sure not to puncture the battery. Since the battery is a form of acid.
  • Using a plastic pry tool is better than a metal tool when working with wire and soft case battery case.
  • Use a plastic pry tool to remove the battery connector from the logic board.
Insérez ici votre traduction
