Aller au contenu principal
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 4 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 2
Étape 2
Insert the pick between the glass to separate the glass from the device. You can also use the suction cups to help lift the glass. When pulling the screen off the chassis, be careful not to cut  the ribbon cable that connects the screen to the logic board. Take your time to pry open the screen from the chassis as you can easily break the screen or crack it.
  • Insert the pick between the glass to separate the glass from the device. You can also use the suction cups to help lift the glass.
  • When pulling the screen off the chassis, be careful not to cut the ribbon cable that connects the screen to the logic board.
  • Take your time to pry open the screen from the chassis as you can easily break the screen or crack it.
Insérez ici votre traduction
