Aller au contenu principal
Info : Vous modifiez actuellement un pré-requis du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 3 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 4
Étape 4
Take a plastic pry to to pry out the battery from its casing. The bottom of the battery has adhesive to hold the battery in place. So using enough pressure to pry the battery is ok . Using two tool different plastic pry to can help give you leverage on areas that are hard to get up.
  • Take a plastic pry to to pry out the battery from its casing.
  • The bottom of the battery has adhesive to hold the battery in place. So using enough pressure to pry the battery is ok .
  • Using two tool different plastic pry to can help give you leverage on areas that are hard to get up.
Insérez ici votre traduction
