Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront le tutoriel% qui comprend cette étape.
Traduction de l’étape 2
Étape 2
The alternator stator is supposed to be insulated from earth.
Check your alternator stator
  • The alternator stator is supposed to be insulated from earth.
  • Unfortunately, as the stator insulation degrades, the coil can become connected to earth. If this happens it will destroy your shiny new electronic regulator. The insulation in the picture is visibly damaged and eventually caused a short circuit...
  • So, check the stator windings are free of earth with a resistance check.
  • Disconnect the three alternator wires and check the resistance from any wire to earth. You should see a reading over 10k ohms.
Insérez ici votre traduction
