Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront le tutoriel% qui comprend cette étape.
Traduction de l’étape 6
Étape 6
Switch the headlight on. The ammeter should show discharge. If it shows positive charge, you need to reverse the ammeter connections.
Test it
  • Switch the headlight on. The ammeter should show discharge. If it shows positive charge, you need to reverse the ammeter connections.
  • Switch the headlight off, put the ignition switch to "IGN" and start the engine as usual
  • The ammeter should show positive charge
  • Switch on the headlight. The ammeter should still show positive charge.
  • Check the horn and brake lights. Everything should work as normal.
Insérez ici votre traduction
