Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Anglais
Français
Traduction de l’étape 4
Étape 4
Take off the points cover Remove the points plate screws and lift the plate away Remove the advance/retard mechanism retaining bolt
Remove the points and cam
  • Take off the points cover
  • Remove the points plate screws and lift the plate away
  • Remove the advance/retard mechanism retaining bolt
  • To remove the advance/retard mechanism from its taper, you will need a suitable puller
  • You can improvise a slide-hammer puller by using one of the long toolbox cover retaining bolts together with a washer and the heaviest socket you can find
  • Screw the puller bolt into the end of the advance/retard mechanism and use the slide hammer to shock the mechanism off its taper
Insérez ici votre traduction
