Aller au contenu principal
Disassembling Asus Transformer Pad TF300
Anglais
Français
Traduction de l’étape 2
Étape 2
Disassembling Asus Transformer Pad TF300: étape 0, image 1 de 1
  • Start by taking the screws from around the frame off.
  • Then remove the screws from this PCB
  • If you are replacing screen components, skip to step 7
  • Remove the little foam pads from the two connectors on the PCB These are for the digitizer
  • Flip up the releases on the plugs to pull out the ribbon cable. (I will show some more detailed pictures of the same process on other connectors.
Insérez ici votre traduction
