Aller au contenu principal
Disassembling Asus Transformer Pad TF300
Anglais
Français
Traduction de l’étape 9
Étape 9
Disassembling Asus Transformer Pad TF300: étape 0, image 1 de 2 Disassembling Asus Transformer Pad TF300: étape 0, image 2 de 2
  • Be careful when removing LCD and when reassembling tablet. not sure when it happened, but apparently I was not careful enough when putting it back together, and this happened. Works perfectly fine otherwise. (Heat gun was not used).
  • It's best to remove all of the adhesive residue from the LCD if you are going to re-use the LCD. Then apply new double sided adhesive (the rubberized kind) for a good "permanent" seal.
  • Be aware there are several different digitizers used in these tablets. If you purchase a replacement digitizer you must get the exact matching part or your digitizer won't work properly.
  • There are also several different revisions of LCD's. Best to get the matching one to avoid any potential problems.
Insérez ici votre traduction
