Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Anglais
Français
Traduction de l’étape 13
Étape 13
Carefully insert a plastic card under the bottom right corner of the battery. Slowly slide the plastic card across the bottom edge of the battery to make a gap for the liquid adhesive remover. At this point, you do not need to push the card very deep under the battery. 0.5 inches (13 mm) is more than sufficient.
  • Carefully insert a plastic card under the bottom right corner of the battery.
  • Slowly slide the plastic card across the bottom edge of the battery to make a gap for the liquid adhesive remover.
  • At this point, you do not need to push the card very deep under the battery. 0.5 inches (13 mm) is more than sufficient.
  • While some bending of the battery pack will be inevitable, try not to form any sharp creases, which will compromise the battery structure and potentially trigger a fire hazard.
Insérez ici votre traduction
