Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Anglais
Français
Traduction de l’étape 29
Étape 29
The goal is to lift the battery contacts high enough such that they clear the screw post underneath the logic board. Slowly lever the extended Battery Blocker upwards, pushing the battery contacts and the logic board up. The logic board is held to the rear case with strong adhesive. Try to lift just enough to loosen the adhesive surrounding the connector.
  • The goal is to lift the battery contacts high enough such that they clear the screw post underneath the logic board.
  • Slowly lever the extended Battery Blocker upwards, pushing the battery contacts and the logic board up.
  • The logic board is held to the rear case with strong adhesive. Try to lift just enough to loosen the adhesive surrounding the connector.
  • Do not lift the logic board up to the point where the top and bottom edge of the logic board separates from the case.
  • Once the extended Battery Blocker has lifted the battery contacts high enough to clear the screw post, pull the battery out of its position.
  • Remove the battery and the Battery Blocker.
Insérez ici votre traduction
