Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Anglais
Français
Traduction de l’étape 30
Étape 30
The next four steps detail how to install a new battery. Never reinstall a used battery. Thoroughly clean the back case of all adhesive residue.
  • The next four steps detail how to install a new battery. Never reinstall a used battery.
  • Thoroughly clean the back case of all adhesive residue.
  • Apply adhesive remover or high concentration (over 90%) isopropyl alcohol to the residue.
  • Use an opening tool to scrape and loosen the residue.
  • Be sure to wipe the residue away in one direction to prevent smearing.
  • It is easier to wipe off the residue when it is sufficiently soaked. Once it starts drying up, the residue becomes incredibly tacky.
  • If you used adhesive remover, be sure to wipe the surface down with isopropyl alcohol to remove any adhesive remover residue.
  • You can remove the masking tape as well as any protective gear once you are done cleaning.
Insérez ici votre traduction
