Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Anglais
Français
Traduction de l’étape 32
Étape 32
Lay the replacement battery pack on top of the extended Battery Blocker. Allow the battery pack to slide in place underneath the logic board as the battery's contacts clear the screw post. If the battery pack's contacts do not slide into place, the contacts may be caught on the logic board's spring contacts. Slide the battery back out, lift one side of the logic board slightly higher, and try again.
  • Lay the replacement battery pack on top of the extended Battery Blocker.
  • Allow the battery pack to slide in place underneath the logic board as the battery's contacts clear the screw post.
  • If the battery pack's contacts do not slide into place, the contacts may be caught on the logic board's spring contacts. Slide the battery back out, lift one side of the logic board slightly higher, and try again.
  • Remove the Battery Blocker.
Insérez ici votre traduction
