Aller au contenu principal
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 12 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 2
Étape 2
There is a high risk of damaging the display panel if this opening procedure is improperly followed. The following four steps show how to pry the rear case from the plastic frame. Read through the steps first before attempting the procedure. There are two different seams between the body and the screen of the phone:
  • There is a high risk of damaging the display panel if this opening procedure is improperly followed.
  • The following four steps show how to pry the rear case from the plastic frame. Read through the steps first before attempting the procedure.
  • There are two different seams between the body and the screen of the phone:
  • Display panel seam: This seam is part of the display assembly. Do not pry at this seam, or you will separate and damage the display panel.
  • Frame seam: This is where the plastic frame meets the back cover. Only pry at this seam.
  • There are twelve clips that hold the frame against the rear case. Be aware of their location as you pry the back cover off in the following steps.
Insérez ici votre traduction
