Aller au contenu principal
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 13 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 11
Étape 11
Use the point of a spudger to lift the display cable connector up and out of its socket on the motherboard. Avoid touching the motherboard with the tip of your spudger. The components surrounding the socket are fragile.
  • Use the point of a spudger to lift the display cable connector up and out of its socket on the motherboard.
  • Avoid touching the motherboard with the tip of your spudger. The components surrounding the socket are fragile.
  • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  • If any part of your screen doesn't respond to touch after your repair re-seat this connector, making sure it clicks fully into place and that there's no dust or other obstruction in the socket.
  • During reassembly, pause here and replace the adhesive around the edges of the display.
Insérez ici votre traduction
