Aller au contenu principal
RHA AM750i headphone driver repair
Anglais
Français
Traduction de l’étape 3
Étape 3
RHA AM750i headphone driver repair, Opening the casing: étape 0, image 1 de 3 RHA AM750i headphone driver repair, Opening the casing: étape 0, image 2 de 3 RHA AM750i headphone driver repair, Opening the casing: étape 0, image 3 de 3
Opening the casing
  • After a small wait for the glue to become soft, you have to use a wrench and a spudger to disconnect the two case parts.
  • The two parts are press-fitted so you need a lot of force to take them apart from each other.
  • Use a high torque to rotate the two parts relative to each other.
  • While rotating pull with low force. When you pull to hard you could break the internal wiring (which is very fragile)
  • slightly move the two parts from each other, use a spudger to complete the disconnection of these two parts.
Insérez ici votre traduction
