Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Anglais
Français
Traduction de l’étape 12
Étape 12
Moving on to the screen, we find the second half of the glass-vibrating earpiece speaker module stuck to the back of the display as we fight through the adhesive. Similar to the back cover, the gap between the frame and the display is virtually non-existent—and the slightly-curved edges of the display don't help, either. We're pretty sure this display is done for after the heat, cutting, and prying it's endured. The strong adhesive strings between the frame and the display fight us like Spider-Man trying to reassemble a boat.
  • Moving on to the screen, we find the second half of the glass-vibrating earpiece speaker module stuck to the back of the display as we fight through the adhesive.
  • Similar to the back cover, the gap between the frame and the display is virtually non-existent—and the slightly-curved edges of the display don't help, either. We're pretty sure this display is done for after the heat, cutting, and prying it's endured.
  • The strong adhesive strings between the frame and the display fight us like Spider-Man trying to reassemble a boat.
  • The question that arises for us is: If your screen should break or crack toward the top half of the phone, will there be any sound distortion with the new earpiece speaker technology? Will it even work at all? We'll investigate—stay tuned.
Passons à l'écran, fièrement protégé par une tenace couche d'adhésif. Nous y trouvons la seconde moitié du module du haut-parleur interne, qui est collée derrière l'écran et fait vibrer la vitre.
Tout comme sur la coque arrière, l'espace entre le châssis et l'écran est pratiquement inexistant – et les bords légèrement incurvés de l'écran n'arrangent pas vraiment les choses. Nous sommes presque sûrs que l'écran ne survivra pas à la procédure chauffer-couper-décoller.
Les filets gluants entre le châssis et l'écran nous livrent une bataille digne de Spider-Man essayant de remonter un bateau.
Une question nous intrigue : en cas de bris ou de fissure de la moitié supérieure de votre écran, y aura-t-il distorsion sonore de la nouvelle technologie du haut-parleur interne ? Est-ce qu'il continuera à marcher ? Nous allons enquêter, restez donc à l'écoute.
