Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront le tutoriel qui comprend cette étape.
Anglais
Français
Traduction de l’étape 5
Étape 5
Lift the home button bracket starting from the left side. Carefully pull it upwards toward the display, making sure not to damage the home button cable. During reassembly, after installing the home button, you'll need to glue this bracket into place to secure it.
  • Lift the home button bracket starting from the left side.
  • Carefully pull it upwards toward the display, making sure not to damage the home button cable.
  • During reassembly, after installing the home button, you'll need to glue this bracket into place to secure it.
  • Scrape off as much of the old adhesive residue as you can, then clean it with acetone or high-concentration (90% or greater) isopropyl alcohol.
  • Secure the bracket with hot-melt glue, superglue, or high-strength double-sided tape. Make sure the bracket is aligned correctly before allowing your adhesive to cure, or the home button will not click when pressed.
Insérez ici votre traduction
