Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Anglais
Français
Traduction de l’étape 5
Étape 5
Peel away the clear backing from the camera bezel adhesive strip, exposing the adhesive on one side. Very carefully line up the rear camera and flash cutouts on inside of the rear glass with the same cutouts on the adhesive strip.
  • Peel away the clear backing from the camera bezel adhesive strip, exposing the adhesive on one side.
  • Very carefully line up the rear camera and flash cutouts on inside of the rear glass with the same cutouts on the adhesive strip.
  • Set the adhesive strip on the rear glass and make sure it does not overlap the edges of the camera or flash cutouts at all.
  • Use your fingers or the flat edge of a spudger to press the adhesive down so that it bonds to the glass.
  • If your part did not come with pre-cut adhesive, use high-bond double-sided tape, such as Tesa 61395, or pieces of a pre-cut adhesive sheet to secure the camera bezel.
Insérez ici votre traduction
