Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 6 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 10
Étape 10
Remove the 1.9 mm Phillips screw that secures the battery power connector. Take extreme care when you insert the battery blocker. Insert it gently and straight in the direction of the logic board. Do not twist or swing the pick side to side.
  • Remove the 1.9 mm Phillips screw that secures the battery power connector.
  • Take extreme care when you insert the battery blocker. Insert it gently and straight in the direction of the logic board. Do not twist or swing the pick side to side.
  • To disconnect the battery, slide one prong of a Battery Blocker under the battery power connector to ensure the power circuit is interrupted.
Enlevez la vis cruciforme de 1,9 mm qui fixe le connecteur d'alimentation de la batterie.
Afin de de couper l'alimentation de la batterie, faites glisser une dent d'un bloqueur de batterie sous le connecteur d'alimentation de la batterie.
[* red] Remove the 1.9 mm Phillips screw that secures the battery power connector.
[* icon_caution] Take extreme care when you insert the battery blocker. Insert it gently and straight in the direction of the logic board. Do not twist or swing the pick side to side.
black] To disconnect the battery, slide one prong of a Battery Blocker under the battery power connector to ensure the power circuit is interrupted.
