Aller au contenu principal
Anglais
Français
Traduction de l’étape 9
Étape 9
To replace the trackpad brackets, you must first remove the black covers that hold them to the upper case. Remove the four 2.7 mm Phillips screws from the two trackpad bracket covers.
  • To replace the trackpad brackets, you must first remove the black covers that hold them to the upper case.
  • Remove the four 2.7 mm Phillips screws from the two trackpad bracket covers.
  • The small metal brackets may fall off once the covers are removed. When replacing them it is easiest to set them in place with a pair of tweezers.
Insérez ici votre traduction
