Aller au contenu principal
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 3 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 2
Étape 2
Carefully peel the battery warning label off the upper case between the battery and the optical drive to reveal an additional Tri-point screw.
  • Carefully peel the battery warning label off the upper case between the battery and the optical drive to reveal an additional Tri-point screw.
  • Remove the last 7.5 mm ( 7.2 mm ) Tri-point screw securing the battery to the upper case.
  • Do not remove the label from the battery.
Décollez soigneusement l'autocollant d'avertissement du boîtier supérieur entre la batterie et le lecteur optique, ce qui révèlera une vis tri-wing supplémentaire.
Dévissez la dernière vis tri-wing de 7,5 mm (7,2 mm) fixant la batterie au boîtier supérieur.
N'enlevez pas l'autocollant de la batterie.
-[* black] Carefully peel the battery warning label off the upper case between the battery and the optical drive to reveal an additional Tri-wing screw.
-[* red] Remove the last 7.5 mm ( 7.2 mm ) Tri-wing screw securing the battery to the upper case.
+[* black] Carefully peel the battery warning label off the upper case between the battery and the optical drive to reveal an additional Tri-point screw.
+[* red] Remove the last 7.5 mm ( 7.2 mm ) Tri-point screw securing the battery to the upper case.
[* icon_caution] Do not remove the label from the battery.
