Aller au contenu principal
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 2 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 5
Étape 5
When reinstalling the trackpad, loosely replace the four Phillips screws and check the alignment of the trackpad on the keyboard side of the upper case. Once you have centered the trackpad in the upper case, tighten the Phillips screws all the way.
  • When reinstalling the trackpad, loosely replace the four Phillips screws and check the alignment of the trackpad on the keyboard side of the upper case.
  • Once you have centered the trackpad in the upper case, tighten the Phillips screws all the way.
  • Use the large Tri-point screw at the bottom of the trackpad to adjust the click stroke.
Lors de la réinstallation du pavé tactile, revissez d'abord les quatre vis Phillips sans les serrer et vérifiez l'alignement du pavé tactile du côté clavier du boîtier supérieur.
Une fois que le pavé tactile est centré dans le boîtier supérieur, serrez complètement les vis Phillips.
A l'aide de la vis trilobe large en bas du pavé tactile, ajustez le clic.
[* black] When reinstalling the trackpad, loosely replace the four Phillips screws and check the alignment of the trackpad on the keyboard side of the upper case.
[* black] Once you have centered the trackpad in the upper case, tighten the Phillips screws all the way.
-[* black] Use the large tri-wing screw at the bottom of the trackpad to adjust the click stroke.
+[* black] Use the large Tri-point screw at the bottom of the trackpad to adjust the click stroke.
